Mazda Lowering Static \  front inner fenders?
views 1327
replies 5
miked   +1y
do they need to be removed to layout in the front?
if not what size tire will come close to it
slammedmini469   +1y
easiest way to figure it out is to measure from the ground to the bottom of the fram, then measure from the ground to the inner fender......
subtract the first number from the second and you will know how tall a tire will fit.....might want to figure on the tire height changing maybe 1/2 inch from camber though....
miked   +1y
another dumb question.. how much will the front end camber when aired out?
delawaredime   +1y
from what ive seen on mine, you can lay out with a 195/50/15 tire, i dont know about a 16" rim/tire but with a set of caddy rims you need to do some cutting... i started cutting mine out the other day, i have yet to do the pass. side, i got to decide what the hell im goin to do with all that crap in there.
miked   +1y
hrm.. what about width.. i think i am fucked as it is.. 8.5 inchs wide.. it looks like it would have less then 1 cm when laid out... between it an the fender.
slammedmini469   +1y
remove crap, toss crap in dumpster, close dumpster.......haha
on my old mazda, i dont think there was ANYTHING left under the hood that didn't 100% have to be there......i spent a couple hours one day with it running unhooking stuff......if it died, i knew it needed to be there....haha
if i remember right, there wasn't much left under there by the time i was done.....fuse block is about all i remember still being on the passenger side fender.....
