Page 1 of 3
Mazda Lowering Static \  layin out on 18's
layin out on 18's
views 4436
replies 27
following 9
madbagger   +1y
how much do i have to tub the firewall and do i have to run drop spindles and drop lower control arms? thanks
dragorbust   +1y
depending on what size tire you run you might not have to tub the firewall. When i bagged mine i bagged it to lay out on 18s (i was still rollin stock 14s) and i had tires on there that added up to be exactly the size of an 18 w/tires and it cleared the firewall. you have to cut out of the lower A-arm for frame clearance if you dont use drop spindles or anything. i would recommend getting spindles or control arms i wish i had some. i got 16" escalade wheels and a 40 series tire right now and the front still lacks about 1/2" from laying out. i was afraid to cut out anymore
baggedb22   +1y
dragorbust, did u flip your lower balljoints if so did u ever think about making a balljoint spacer so you can lay out??
dragorbust   +1y
yeah i flipped my balljoints... ive heard about that balljoint spacer, is that safe on my daily driver?
slammed83mazda   +1y
do they make spindles for a 83? if not im guessing flipping the balljoints are my only alternative ive running 16" z-71s similar to dragorbust's prob im 1/4" from laying on front crossmember
baggedb22   +1y
dragorbust Yes its safe i welded mine straight to the lower control arms and just put holes in the spacers so the bolts can go threw to bolt the lower balljoint down...
baggedb22   +1y
Slammed83Mazda Im almost positive they only make spindles for 86-93 mazda bseries pickups...
slammed83mazda   +1y
damn that blows, ill take pics of my suspension up front and how i have everything set up and ill post them and get feedback from you guys.
thanks for the quick reply, i think i need upper arms badly
bagman   +1y
im tuckin these big a$$ baloons(26 inches top to bottom) with 3/4 inch spacers between my ball joints...but im 1/4 from crossmember on the ground,because tires hit firewall...no prob though,i got some z's in the machine shop gettin bored out
madbagger   +1y
since drop spindles won't fit in my stock wheels can i get drop lower control arms and flip my ball joints and lay out on stock wheels and how tall is an 18" wheel with a 35 series tire?
