Mazda Lowering Static \  How much psi???
How much psi???
views 766
replies 5
baggedb22   +1y
Hey guys just wandering if it would be a big problem too run 200psi in my Airlift gen 11 180 psi bags?? I don't get much lift in the front with the 351w Right now im running a 175psi switch, and that gets me about 3/4 over the front tires...Remember this will be my daily by next spring..Thanks in advance for the advice!
drpdmazda   +1y
its always a risk for blowout any time you go over max rated psi, especially if your already putting a heavy load on them form the motor, you may have to step up to a heavier duty bag, with more lift, i know there is at least one set put there that gets a good bit more lift than the regular bags, not sure of the name right now, im sure someone will chime in and let us know the name of them, and im pretty sure they hold more psi as well
baggedb22   +1y
Airlifts get good lift, and my trucks set up to get good lift with the bags in close to the pivet point, I was just wandering what everyone thinks about runnin 200 psi in airlift bags...
slammed83mazda   +1y
ig ot air lift bags and i run mine to 210 all day long my buddy freddy ran 230 to them and they were showing signs of the seals ripping apart but ya 200 psi is fine ive never had a problem with it, only problem ive ever had is my lil 3/8" smc valves sticking at 200
baggedb22   +1y
Ok, thanks alot man!
slammed83mazda   +1y
not a problem man, but i do recommend with running this high of a psi to try to have your bags mounted as vertical as possible, you dont want them in a bend with that high of a psi
