Mazda Lowering Static \  How do you mount these brackets?
views 1635
replies 12
following 7
mpenner49   +1y
I saw this in another post but I am confussed how and wheer you mount these?
mark   +1y
you weld those on the side of the frame between the upper and lower control arms
mpenner49   +1y
So you mean inbetween the control arms?
baggedb22   +1y
Hope this helps ya out most people dont use sd's lower bag thing..
dragorbust   +1y
you weld the top bag bracket in between the top and bottom control arms. its welded to the frame and the two triangle looking things weld under it on the sides, sqare side to the frame. they are for extra support. the long thick ass bar...who knows what thats for. i cut a piece of it off and put it under the bottom bag bracket to straighten out the bag a little bit. after you get it laid, take a jack and jack the contol arms all the way up and then put your bag in there and compress it all the way down. then put the top bag bracket in there and that will tell you where, and what angle the bracket needs to be welded in at. and if you get the bag all the way compressed when its laid all the way out, it will give you the maximum lift that you will get from layin frame, which aint much for a mazda we all know that.
mpenner49   +1y
Wow I feel like a complete moron but I don't understand where thinsg are going? Anyone have a picture of how they bagged there front? or picture of how to do this?
dragorbust   +1y
dont feel like a moron i felt the same way when we were tryin to figure out how to bag mine in the front. i dont have any pics of mine....i need to take some though. ill try to pick up a camera soon and ill scan em and try to post some for you. Theres really not much info on how to do the front of a mazda out there though its weird.
mpenner49   +1y
Thanks Bro.. That would be great!
dragorbust   +1y
yeah no problem man
okdraggernc   +1y
The mounts you show from ssd is a torsion bar mount type. It dont mount anywhere near the front control arms. With minor cutting anything can be made to work.
