engine running like shit
rangerdanger
hey guys, i got a 94 pup. its the 2.3 carb motor. I CANNOT get this thing to idle right. ive replaced vacumm lines, cleaned the carb, ran cleaner thru it, new plugs, oil changes, air filters. Ive adjusted it over and over, and tried everything i can on it to get it to just idle right.
Can anyone help me, or tell me what i might need or dont need. Just to get this thing runnin good.
It idles from 1 to 2000 after i drive it for a little while, back and forth, 1,2,1,2,1,2, and sometimes itll idle at 600 and just barely wants to die. I dunno.
I
isuzueh
sounds like a crank sensor?? if isuzu's are equiped with them...my jeep did that and it was the crank sensor
rangerdanger
crank sensor eh...weres that located, if it has one??
perfectlywicked's avatar
perfectlywicked
sounds like you have carb problems the 2.3 is known for that thats why most people go with the weber carbs
eatinpavement's avatar
eatinpavement
its probably the intake manifold gasket. thats a common problem on these trucks. i've had it with all of the zu's ive owned. to check it let the truck idle and spray some carb cleaner around where the intake meets the head if idle picks up then theres your problem. the gaskets leaking making the intake lose vaccum.
eatinpavement
any progress?
Related Discussions in Engine
fuel cell
last post by tycox +1y
0
