Mazda Lowering Static \  Cross member
Cross member
views 752
replies 1
following 2
pont   +1y
i guess this will go here since it has to do with Suspension. as some of you might rember i got a 92 B2200 not to long ago with a bad oil pump well to pull the oil pan to replace it i had to pull the crossmember under the pan. it was a PTA to get out when i pulled it and now i cant that SOB back in the bolt holes do not line up right. and i was wondering if anyone had a idea on how to make them line up. or tell me if you pulled yours and it was a PTA. the truck is on jackstands so i could get under it as well.
hybrid   +1y
your should have wrapped a come along around your frame rails and tightened the poo out of it.you might still be able to do that and make them line up again.lol that x member is more important than it looks.
