Page 1 of 3
Mazda Lowering Static \  how can i go lower
how can i go lower
views 3205
replies 21
following 12
throwinsparksnla   +1y
ive got a 5/6 drop on my 92 b2200 and i have djm cal-max supershocks all the way around. bummpstop are cut half way off. ive taken some leaf sprngs out(ive only got 2 on each side now).i only have about an inch and half of travel or so. question is, how can i go lower? im waitin until i go to wyotech to bag it but for right now, i want it lower. what can i do to go lower
miked   +1y
other then smaller tires, i really dont see anything besides air shocks...
baggedb22   +1y
notch the frame..
2fine89   +1y
Pick up a FAT CHICK - should be good for an inch or 2 ...
thetornado   +1y
hahahahahahhaha
f n lo   +1y
notch the back frame, drop spindles and lower droped arms, .... get rid of the bumpstops and ride rigid...that what i did all summer, bumpy as hell but tis low!!lol
nytrdr24   +1y
just don't let here ride in the bed, your bound to break a spring!
well, except for buy control arms and all that other stuff, since i run a really tight budget, wut if i just buy shorter shocks like the toxic drop shocks, i think those are an inch or so shorter. as for the bump stops, i could either take them off or cut them down some more, i dont have much left. what about flippin my ball joints.
ok well never mind about the shocks cause that wont do anything, i wasnt really thinkin on that i just put it down
nytrdr24   +1y
BOUT ALL THAT CAN BE DONE IN THE REAR IS A C NOTCH & BLOCKS
WHICH WOULD BE A ROUGH RIDE. IN THE FRONT IF YOU DON'T HAVE CONTROL ARMS OR SPINDLES, & JUST HAVE THE T-BARS CRANKED DOWN IS
FLIP THE BALL JOINTS. THEN YOUR SHOCKS ARE ONLY FOR A 3"-4" DROP FRONT & REAR, SO YOU RUN THE CHANCE OF BUSTN A SHOCK IF YOU BOTTOM OUT TOO HARD.
