Mazda Lowering Static \  Post Your Air Ride Set Up!
views 2383
replies 10
following 11
slammed83mazda   +1y
Like The Topic, Says Im just curious to what kinda set up everyone is running now since it is after christmas and all, and also tax returns are coming up.
So post what your running on your truck as far as air ride, or what you have on the way.
4 Brand New firestones 2500
2 450 viar comprssors
Wishbone 3 Link
8" Notch/Bags on Axle
12 Gallon tank/Hydraulic line all way around
phatkix   +1y
2 2500's and 2 2600 firestones
belt driven compressor from a bus
full custom three link
can't remeber what size notch/bags over axle
12 gallon tank/8 1/2 inch valves/1/2inch air brake line
mullet   +1y
viair 450
firestone 2500's all around
SMC 3/8in valves
1/2in line
malteese bridge kit from SD (NOT SSD IMPULSE!)
baggedb22   +1y
Airlift Gen II 180 psi bags 2500's in front 2600's in rear
Jasons Triangulated 4 link
All hand fabbed brackets
Blitzluft valves
2" Aim Spindles
12 gallon 8 port tank
ViAir 380 and Thomas 337 comps (engine driven as soon as i get the brackets for the 351w)
All 1/2 line and fittings
200psi daily...
tucnrim2004   +1y
Slam R62's up front and firestone 2600's out back
FBI Mini heavy duty 4 Link
FBI Mini 7 gallon tank
8 1/2" SMC valves
1/2" Air Line
Hand made 10" Notch
Viar 380 ( awaiting engine driven comp )
1/2" Fittings
Bags over axle ( Soon to be on the bars )
midnightmike   +1y
firestone 2500's allthe way around
8 smc 1/2" valves
1/2" line
2 viair 450's
50/50 4link
8"notch
2 10 gallon tanks
3 easystreet gauges
10 switch box
now under consturction, loosing 1 tank, adding 12gallon 8 port tank and putting othe 10gallon under bed tub rear wells and spray on bed liner and edc
mazdizzle   +1y
My setup isn't complete yet but here is what I have so far
8 blitzluft 1/2 inch valves
sanden 708 edc
super lift super pivot 4 link from SD
slam re72's in rear and soon to have re62's in front
monster notch I bought off ebay a while ago
dub city escalade 10 switch box made by myself
all parker 1/2 fittings and line
low87dawg   +1y
8 1/2" smc valves
2500 and 2600 contitec bags
oasis hp1000
suicide doors triangulated 4link
8" step notch
1/2" line and press fittings that ive spent like $170 in
3 easystreet gauges
12 gallon tank
10 switch box
about to be kustom werks control arms i gave up on byc unless he contacts me soon
lots of custom brackets made taking so much time
slammed91b5000   +1y
Oasis
air lift gen II 2500 and 2600 (rear bags on link bars)
1/2" line
1/2" valves
10 switches
7 gallon tank
shocks on all corners
down2earthdawg   +1y
kustom werks upper and lower arms
Aim 2" drop spindles
2 2500lbs bags
2 2600lbs bags
custom all foward 4 link with SD link ends and supper lift bag kit bags on bars
super slim 5 gallon tank mounted in the cab plus and a viair 380
soon to have two
1/2 fills in front and rear and 3/8 dumps in front and 1/2 inch in rear
all ran on half inch line with D.O.T. all Brass push to lock fittings
Post was last edited on Mar 17, 2006 11:03. This post has been edited 1 times.
