Mazda Lowering Static \  notch and tosion bracket question?
views 916
replies 3
shapinoweno   +1y
Hey guys I got a quick question guys,
Well I bought my brackets from gravity werks and I need to know;
On the torsion brackets do I weld the triangle pieaces on top of the uper plate or below it? If that makes any sence.
Also the gravity werks notch is all pre welded. So it is one piece, so do I just set it on top of the frame and weld it in place then cut out the portion of frame? I'm not shure what I am suposed to do.
Cause suicidedoors notch is in pieces so you weld them on 1 by 1.
Please give me some insight
slammed83mazda   +1y
lol, already pre-welded. that may cause u some problems, cuase if something dont line up its not lookin good for you.
shapinoweno   +1y
Ya I thought that was weird when I seen them. But they should work mike mock knows what he's doing I'm just confused, mabye ill call him tommorow
baggedb22   +1y
You could cut the inside and the top of the frame out and sit it down in there, Then u would have more sides to weld too. And for the torsion brackets mount the gussests down on the frame, it will make the frame less likly to tear.
