Mazda Lowering Static \  how low?
how low?
views 927
replies 7
following 6
mazdawgydawg   +1y
how low would my truck be if i did a static drop with out blocks in the rear? and does anyone have pics of it done? or everyone uses blocks?
speedwobble   +1y
I used blocks and monoleafs on my first one
mazdawgydawg   +1y
yea, my buddy is gonna send me his blocks when he find them i was gonna static it with out them till then and then add them
team haymaker   +1y
id just wait, the only ways to static without would be removing springs, or a D-ARCH
mazdawgydawg   +1y
i was just gonna rip the springs other then that main long one and the short fat on like remove everything int he middle other then the 2 outer ones
hybrid   +1y
it would put your axle on the frame.then you can go to smaller tires.
1hotdawg   +1y
Just gettin rid of the 2 inside leaves won't leave it "on the frame" lol. That's why everyone uses 3 or 4" blocks as well, to actually get it close to the frame.
I have my 2 insides off and using 3" blocks and it sat the rear just on the bumpstops...one side was actually about 1/4" off the stops, but the other was on it.
I wouldn't advise anymore than a 3" and removing the leaves if you're wanting to go static and have any resemblence of a ride left. GET AIR SHOCKS TOO! When I had my Chevy wheels on, like in my avatar, I was down on 5" of block with all my leafs in cept the overload lol, and if it weren't for me adding the air shocks I would have been hitting frame on almost every bump, but the air shocks helped stop that.
In the front to be as low as the rear, grind off your bump stop brackets, or/and do the ball joint flip. That's what I'm gonna do as soon as I get some thinner wheels. Right now that bracket helps keep my tire from nailing my fenders
Post was last edited on Mar 09, 2006 09:03. This post has been edited 1 times.
baggedb22   +1y
1HotDawg is right just pulling leaves will only get u about an inch drop or so, Throw a 3" block in there and shave down the bumpstop alittle...
