Mazda Lowering Static \  lowering a 86 b2000
lowering a 86 b2000
views 5133
replies 2
cbomb86da   +1y
Hey im new to the mini truck scene and i was wondering what was the best way to lower my truck?? Its a 86 mazda b2000 reg cab 5 spd...I've heard cranking the torsions and blocks in the rear but i use it as a daily so not 2 low...
lukeinva   +1y
you can get blocks from 2-4inches then just crank the torsions in the front. Or if you want to spend some money you can get leaf springs for the rear which will give you a 3in drop, then in the front get some drop spindles. If you're just looking for a cheap way to do it go with cranking the torsion bars and some blocks. They are like $40 bucks.
nytrdr24   +1y
^^^ WHAT HE SAID, OR YOU COULD GET THE LOWER CONTROL ARMS FOR THE FRONT INSEAD OF THE SPINDLES...... EITHER WAY YOU GO I WOULD INVEST IN A SET OF LOWERED SHOCKS LIKE TOXIC SHOCKS OR NITRO DROP SHOCKS ALL THE WAY AROUND, AND AN ALIGNMENT FOR THE FRONT AS YOUR CAMBER WILL BE OFF AND IT BEING A DAILY YOU WILL CHEW UP YOUR TIRES.
