2600's up front?
2600's up front?
sketchystreet
Im getting ready to bag the front and i wasnt sure if i could fit the 2600s. Id prob get the slam version so they dont bellow as much. Is it possible or will it hit the tie rods or frame or spindle? If its not worth the trouble ill stick wiht 2500 but id like to have the extra lift and better ride
baggedb22
My buddy has some Airlift 2600's in the front of his with 3" lower control arms it doesn't rub but its to close for comfort for me...
slammed83mazda's avatar
slammed83mazda
slams would make up for the extra lift.
sketchystreet
the main reason i like bigger bags is the ride, full lift at 60-80 psi is awesome and comfortable
balcar's avatar
balcar
its not a problem, just cup the frame behind the bag, push the bag in some and u will be set. Only should be done if you are comfortable with welding/fabercating though. The last one I did was using airlift bags, but i perfer conitech ones.
minimazda93
2600s infront of a mazda is only good for the ride quality, hell a 2500 can top th suspension out but if you wanna do it id do what balcar said, notch out the frame behind the bag, about an inch or so, replate it and be careful nothing rubs its not too hard...
sketchystreet
ok 2600's it is
