Mazda Lowering Static \  how much to cut?+10 marks
views 996
replies 6
following 5
low87dawg   +1y
how much of the rocker including the pinch weld do i need to cut off for a
3 1/2" body drop
need an answer if u are only sure
so i can get those bitches in the scrap pile and so i can get the body on the ground
down2earthdawg   +1y
use a tapemeasure and mesure from the floor to your rocker 3 1/2 inches mark it and then start cutting.
impulse   +1y
scarey.
baha   +1y
don't use so many question marks simma down now lol
sketchystreet   +1y
cut a little bit at a time, hold up something strait across the bottom of the frame. once the body is level or pretty close you know where you need to cut. then jsut hold a strait edge from front to back and draw your line. its ok if y ou have a tiny bit hanging over just drag it flat
impulse   +1y
just body drop one side... that would be craaaaaaaaaaaaaaaaaaaaaaaaazy!
low87dawg   +1y
sorry man
and i think im gonna stick with both sides
