Mazda Lowering Static \  Dual Port, or Single Port?
views 1192
replies 5
madmazda   +1y
As The Title says, Whats the Difference between the too? Pro's and Cons, If Any....Thanks.
robbie   +1y
dual port your run 2 lift valves per bag to make it fast. Really no need for them unless you 1. wanted to hop alot. or 2. you could run your lift valve in one port and dump valve in the other port so you didn't have to T them off.
madmazda   +1y
Alright, and If i was to go with Dual port, and run a T off of 1 port, is there something i could use to fitting plug for the other port until i decided i wanted to use it...instead of replacing the bag, if i decided i wanted dual later on down the line? but for now use a dual port bag as a single.
baggedtwenty   +1y
i got dual port on my mazda,i like it alot,lift hella quick off of air,ill se if i can get a small vid up for you if you like,down is it drops fast
mark   +1y
yes u can get a plug for it
madmazda   +1y
alright Sweet, that would be cool baggedtwenty, post it up, or email/pm me a link to it...Thanks.
