need more info on baggin front.
shapinoweno
Hey guys, well i have been sitting on installing my bags on my 89 mazda b2000 for months. I allready installed the notch and have cut out the front metal in front of the frame. But i really need more info on installing the front bag brackets. If someone can please messure the brackets length installed after being trimed. I want to make shure i cut it to the right length. also what kind of angle are the brackets welded in at?
Please help. I am getting to the point that if i dont finish baggin the truck i am gonna have to sell it cause i dont have the room to store it anymore.
Please help
baggedb22
The brackets can be different lengths just set the back in as straight as possible tack the brackets, compress the bag with a jack to make sure it wont rub on anything, frame, lower balljoint, bag mounts, then jack the truck up as if the bag was aired up make sure the upper balljoint is no where close to the bag, also the closer to the pivot point u put the bag the more lift you will get, Just becarefull when some bags compress they expand. It's not to hard once u start into it u will get the idea just make sure the bag doesn't run and is pretty straight...
