Mazda Lowering Static \  layin on 18s
layin on 18s
views 694
replies 1
following 2
assdragginsdime   +1y
Alright. well im considering keepin my truck and switchin over to bags, to save weight.. Because i have like 400lbs of batteries on the back of my frame, and every time i hit a bump,, my whoke frame flexes real bad. Which makes the ride quality of the truck absolutely horrible. So i figure if i save weight, it wont be as bouncy, and al in all will be a better suitable daily driver.
Right now my truck has hydros, Adn lays on 225/40/18s. The front setup is pie cut uppers, and these real ghetto 3" drop lower control arms. I have no clue if the ball joints were flipped or not.. since the truck was juiced when i got it..
so what i want to do is get rid of the 3" drop lowers, And get some stock ones. But i need to know what im going to need to do to get it to lay out. And does anyone have pictures of a RE-7 bag in front on their setup?
bagdb2200   +1y
Since your uppers are already cut, you should just find out if the lower ball joint is flipped, then when you get new lower arms just have to cut a lil off of them to clear the frame and you should lay. That's all that's done to my truck and it lays on a 215/45/17 which I believe is the same height as the 18's
