rides
market
More
Events
Gallery
Wiki
Store
Threads
Rides
Market
Events
Gallery
Wiki
Store
Browse
Mazda Lowering Static
\ cuttin off shock mount bubble for bagging???
Mazda Suspension
Mazda Tech
views 771
replies 3
sketchystreet
where the uper control arm is mounted its a hollow peice. should i mount my brackets to that hollow peice or cut it out and mount it to the frame. i dont want to loose structure on the upper control arm/
madmazda
Frame, No? Is it a Mazda?
sketchystreet
i cut it off so that the frame is exposed. im going to use some 1/4 inch plate to make sure i didnt loose any strenght to the upper control arm mount.
laynrail
I cut the hump off the frame 4mm from the actual rail.
Then I plated the frame with 4mm plate over the stock hole in the frame. Then put my brackets over that.
4mm Is close to your 1/4 inch I think.
