Mazda Lowering Static \  any type of brake upgrades?
views 1711
replies 11
following 5
valiant   +1y
Since I am now planning out my 5.0 swap, I want to make sure I have all angles planned out. I will need bigger brakes, but I dont know how to get them. will a toyota spindle bolt where our spindle does? only reason I ask is there are tons of companies that sell large brake kits for toyotas. I am only really worried about the front right now, cuase I plan on swapping a shortend 9" later after its driving.
I will not be baggin this truck, so there is no restriction there. I am going to a pro tour kind of look. going to upgrade to some sway-a-way torsions and add an air assist towing system to the back.
I was going to convert this to a 4x4, but I got the OK to get a fullsized 4x4 truck again.
Thanks for the help,
Mike
nytrdr24   +1y
YOU CAN USE THE YOTA SPINDLES, BUT HAVE TO ADAPT THE STEERING LINKAGE & BALL JOINTS TO OUR CONTROL ARMS....DONT' KNOW ABOUT BRAKE UPGRADES ON THE YOTAS, BUT YOU CAN GET SLOTTED & X-DRILLED ROTORS FOR THE MAZDAS FROM J.C. WHITNEY ON THE CHEAP...PUT THEM WITH SOME GOOD PADS ON & YOU OUGHT TO HAVE BETTER BREAKING. I DO KNOW THAT YOU CAN GET A DISC BRAKE CONVERSION FOR A YOTA REAREND....IF YOU AREN'T GOING TO "BUILD THE V8" THEN A YOTA V6 REAR WOULD HOLD UP TO WHAT THE V8 WOULD PUT OUT, THEY ARE 8" RING GEARS...YOU CAN GET SEVERAL DIFFERENT GEAR RATIOS, & ALSO LSD'S OR LOCKERS....JUST A THOUGHT....
PADS & ROTORS FOR MAZDA FRONT.....$65 PADS, $100 ROTORS
DISC BRAKE CONVERSION FOR YOTA REAR.....@$600
valiant   +1y
so the slotted and crossdrilled rotors for a mazda would be plenty for a V8? with the highest quality brake pads? that would be easier, would they fit on a drop spindle? I plan on running a rim larger then 17" so I dont have to wrry about the limitations on drop spindles.
Thanks,
Mike
valiant   +1y
I cant seem to find them, did they discountinue them or do they only make them for a certain year. Mine is an 86 thanx.
-Mike
hocbj23   +1y
Just put slotted rotors {thanks NYTRD} and Akebono ceramic pads on my 2200.Stops like a champ with plenty of pedal feel.I would think they would haul ur ride down as well.BJ
hocbj23   +1y
Bump.Sorry.I saw some really nice looking finned and vented drums today on someones web site along with some quality looking rear brake shoes.Will try to find it if u dont want to go rear discs.BJ
nytrdr24   +1y
here are the part #'s form jc whitney
492661 DRIVER'S SIDE DRILLED & SLOTTED PERFORMA
Quantity: 1 @ Total Price:$49.99 USD
492662 PASSENGER'S SIDE DRILLED & SLOTTED PERFO
they will fit the dropped spindles as they use the mazda hub assembly which will require a mazda rotor....if you get these or just plain slotted rotors with some good pads & upgrade to some braided lines from goodridge or russel i think they should slow the ole dawg down fine.....esp if you did a yota rear axle w/ disc brake conversion....
sierrax   +1y
Get the cross drilled slotted rotors and you'll be fine (got them from a shop in Cambridge, ON). I warped the shit outta the stock ones in about 2 weeks, switched to the cross/slot and was fine for years. Just make sure you get good pad with them.
midnightmike   +1y
u can pick up a set of brembo cross drilled rotors for 260$ cdn
nytrdr24   +1y
one other suggestion any type of rotors plain or perfomance, make sure you follow the bed-in procedures....if you get the slotted and or slotted / x-drilled ones it wouldn't be a bad idea to get them cryo treated....it's $30 a rotor & they won't warp or crack, & it will extend the life of them as well...
check out
