bagin' the front end
lowerexpectations34
does anyone have any tips?
ill post some pics when im done.
baggedb22
What size wheel are u gonna lay? cut all the bump stop brackets off the front end, smooth the lower a-arm you can flip the balljoint if need be, when u put the gussets for the upper bag plates in but them downwards b/c the stock mazda frame is thin and theres a hole right where the bag will sit, you can ditch the sway bar, the closer the bag is to the pivet point the more lift u will get, and make sure the bag doesn't rub! Good luck and we need to go draggin then bro!
lowerexpectations34
thanks for the help and im runin the stocker's for a little then 14inch pathfinder's that new style when i get tires
hell yeah we'll go drangin
baggedb22
ok kool man, hit me up on aol or pm me if u have any other questions...
lowerexpectations34
what about drop spindles one of my buddys gave me a set should i use them?
joshbrennan
those drop spindles will not allow you to run those pathfinders as you need to run at least a 17" wheel with them, as i learned the hard way. they also push the wheel out a bit.
lowerexpectations34
thanks alot and you saved me some time to
sketchystreet
just finished my mounts and notching and pie cutting. when the truck is layed the bag rubs the flippled ball joint. do you think its gunna be a problem.
baggedb22
Yea man, u don't want the bag rubbing anything its not worth taking the chances...
lowerexpectations34
you you wanna be stuck on the side of the road
