Mazda Lowering Static \  Whats all needed in bagging
views 649
replies 3
d16ej1   +1y
Ok I have a 89 b2200 cab plus and I want to do this myself and I have some idea on this but can someone give me the full list of what I will need perferrable suicide doors. And man I have been doing searches all day here at work lol but I cant find a DIY on bagging a maz I dont want total mt dew extreme just sitting on the ground can someone help me or point me in the right direction
framedragger2   +1y
well first off youll need to determine how fast you want your truck to lift.. 3/8 valves, airline, and bags will be fine. you can fit a 2500 up front with only a little bit of cuting. if you want to cut a lot more you can stuff a 2600 up front. but in all just cut your bump stop mounts off and if you look under the upper controll arm youll see a big piece of frame that you bumpstop was mounted to, cut it out, once you do this you will see your frame under neath, trim everything so your bag doesnt rub anything, you can use the bag mounts from ssd. as far as the rear goes you can get just about any 4-link system and just mount your bags on the axle for a simple set up. its gonna ride a little more stiffer, but if you want a better ride mount your bags on your lower or upper bars. youll have to notch your frame you can get a notch from ssd or pretty much every any other person that sells bags. if you need anything more i can go into more detail for you
d16ej1   +1y
thanks for the description anyone got any DIY pics to go with
joshbrennan   +1y
i haven't taken a real in depth look at this site, but seems like it could be a good start.
