fender well questions*please answer*
throwinsparksnla
i was wondering if im going to have to cut out a lot of the front fender well to lay out completely, its on the stock 14's with a 195/60, i think, maybe 65 but im sure its a 60, also, if i do, what do i do with all the shit on the left side, where the battery is? i have no clue what all that is...thanks for any help
Post was last edited on Sep 13, 2006 12:40. Edited 1 time.
blare
There is a post about this somewhere else.
Anyways I had a 195/65. My truck was not laying in the front with stock inner fenders. It was close but the tires rub.
In the rear you are going to have to cut the bed supports near the wheel. It will lay the rear hard, but after you drag some frame off its gonna start rubbing the top of the fender.
trashed's avatar
trashed
i had 195/40 16's which have a smaller OD than th 60 series 14s and it rubbed the fenderwells. just unbolt all the shit from the passenger side fenderwell and zip tie it to the air cleaner clip and firewall and cut that shit out.
shapinoweno
on the real you just have to get in there and start moving shit. First cut out the inner fenders. Then i also notched the bracket were my battery sat. once notched it dosent rub the tire. The stuff on the left side is all your smog shit. Mine came out pretty clean. i will have to get pics up later. but i had to extend six wires, and i just started mounting things were they seem to fit. you will get a better idea when you see the pics. I will get them on later tonight.
southernrazed
yea cut that shit out...who needs nner fenders...a sawzal and some selftapping screws will be your best freinds
