will somebody answer this
throwinsparksnla
what all should i have to do to lay out in the front with the stock 14 tire size 195/60
blare
damn dude make a post everytime a thought pops in your head.
throwinsparksnla
well, i cant get anybody to answer any of my posts except for like 1 person on some, most none and when somebody does answer it, its not really what im lookin for and they dont explain it well enough. if i could get my questions answered, i wouldnt post so much, but screw it, i can figure it out on my own, maybe find another forum that will actually help me out
nytrdr24's avatar
nytrdr24
let some air out of those 60 series tires j/k haha!
nytrdr24's avatar
nytrdr24
i assume that your are bag'd in the front or you wouldn't be askin this q...?
from what i know on an air bag setup proper bag mountin in the front is key to gettin as low as you can (also for the most amount of travel).....do you have the torsion bars installed still....is the sway bar still hooked up? have you cut the bump stop mount off the frame....are you running shocks up front.....if your bag'd i don't see any reason that you shouldn't lay in front on 14's except for your runnin 60 series tires...which are a little tall if you ask me.....but i'm no bag expert...may want to check on bagginit.com it is a very informative site on bag'n!
throwinsparksnla
im not bagged in the front yet, ot at alli will be, im startin on everything this weekend. i finally got my 4 link in today but i just wanted to know what i need to do to lay out in the front
nytrdr24's avatar
nytrdr24
well, the best i can tell you is measure twice or three times cut once....make sure your on a level surface...if it isn't make sure to level
the truck before you do any cutting........check here in the suspension section for front bag'n topics, put something on paper as to how you want to do it & use that as your guide lines for the actual work.
blare
I wasn't trying to be an ass, but this has been gone over multiple times in other threads. Thats why no one is responding. Im also pretty sure in your other thread you only asked if you would need to cut your fenders to lay.
mark
you got your answer right there, on the other hand, try
specifically name the title "how do i bag my mazda" and you'll get a lot of help
