Mazda Lowering Static \  brake proportional valve
views 920
replies 4
baggedb2000guy   +1y
What do you do with the rear brake proportional valve some people say take it out ,do i remount it somewhere or just take it out
,Also whats the diff diameter
its for a 1990 b2000
nytrdr24   +1y
are you talking bout the bpv/abs valve mounted onto the passenger side frame rail right above the axle?....you can take it out, but the rear abs won't function..... on the diff dia., are you wanting the ring gear size? not quite sure on the size, i have heard that you can swap out an rx-7's third member w/lsd out of a non-turbo model & it will fit in our axles....i'll have to do some more checking on the size tho.....
baggedb2000guy   +1y
thanks
Yep the brake valve mounted on the drivers frame rail
il just take it out was told if you brake hard the rear will lock up
nytrdr24   +1y
any vehicle will do that w/o abs.....you could get an inline adjustable valve & set it to where the rear won't lock up on you.....
baggedb22   +1y
i didn't have mine for awhile, i just ran my new brake like like it was never there and didn't have a problem now i got 4 wheel discs though so who knows...
