Mazda Lowering Static \  front and rear bumpstop relocation
views 854
replies 4
baggedb2000guy   +1y
can someone please post some pics or describe where theyv,e relocated there front and rear bumpstops as they have to be in for cert
phatkix   +1y
theres a pic in that thread of how my front ones are mounted....
balcar   +1y
Are you lowering your ride or lifting it? I'd assume you are lowering it, if thats so you can just take them off and cut them in half, or bolt in some energy suspension ones that are about 1/2 the size and look cool cause they are red. (sometimes you can get them other colors)
baggedb2000guy   +1y
bagged it but the cert requires bump stops to be in
Rears not so bad just mounted in the factory position ,But the fronts abit trickyer,
Also to lay the front on 18s with stock spindles you just notch the lower control arm ,And cut the inner fenders ?
balcar   +1y
cut the front fenders, yes, but I havn't had to notch the lower arm for 18s...
