Mazda Lowering Static \  Vibration?
Vibration?
views 732
replies 3
1hotdawg   +1y
I'm getting a pretty bad vibration when allowing the truck to coast down below say 20mph, or if I'm riding in a parking lot in 1st or 2nd gear. It doesn't matter if the truck is in gear or not, so I figure it's either the bearing below the cab of the truck around the drive shat...2 piece shaft...that's going bad, or some kind of bearing in the rearend. Any ideas?
slammedyota91   +1y
yep... carrier bearing is the word your looking for.. and yes they go bad if you have a poor pinion angle.. and will cause vibrations at various speeds
gravity5   +1y
Could be a carrier bearing, could also be U joints or a bad tire, or possibly rear end problems....best to pop underneath and take a good look at everything.
1hotdawg   +1y
Carrier bearing is the one on the driveshaft correct? I guess my pinon may be bad, lowered with 3" straight blocks and monoleafed :O
