Mazda Lowering Static \  front cantilever, need opinions!
views 1886
replies 11
following 9
laydoutb26   +1y
I'm thinkin of a way to do a cantilever on the front of my truck... was thinkin of puttin a bar from one side of the frame, over the engine, and to the other side of the frame. then mount the bag on that bar, put a heim or super pivot on the frame and connect that to the lower arm... somethin like this...
think that would work?
mazdapromp3   +1y
Have you ever thought about putting bags on your torsion bars? I've seen a vw bus with 4 inch hydros on torsion bars, the spring rate stays the same, and the height is adjusted through indexing. (if that makes any sense?)
There is a Yota featured in MT mag that uses a double control arm cantilever with coil overs. A small set of control arms inside a larger set of outer arms.
If you look way back in MT mag there was another Yota with a cantilever air shock setup.
laydoutb26   +1y
The setup on a fullsize C-10
mazdapromp3   +1y
Thats nice, but it might be hard to shoehorn a setup like that under the hood of a mazda, but anything is possible.
madbagger   +1y
the bags on torsion bar setup is made by AIM but i dont think they sell any. its just a weird idea. but the setup on that c-10 is sweet.
lost_b2200   +1y
Can anyone give me more info about putting bags on the torsions? Like where they would go in that setup?
laydoutb26   +1y
your ride quality would suffer like no other... idk where they would go but i wouldn't recommend it
gravity5   +1y
you could do a cantilever like you drew...but a bar will not be strong enough by itself...you will need some form of gusset on top....and don't forget that the ag will travel in a sever arc and not inline vertically in that type of cantilever setup.
phatkix   +1y
man that looks cool, i'd love to see it in action......
good luck with it.
mazdawg(mikey)   +1y
why not just mount the bag on the upper a-arm?
