Mazda Lowering Static \  cheap shocks?
cheap shocks?
views 1440
replies 10
following 6
widowb   +1y
i need some shocks for the front... a friend told me just to find out what uses the same type of shock thats shorter and just use that.. what uses it?
gravity5   +1y
Measure the length you need and the end types then just go to the local jobber, open the monroe book and find which shocks fit your requirements.
originalmazdawg   +1y
My guy at the local auto parts did the research for me. He got me the front shocks from a late model (I think it was a '95) Toyota RV. I had to remove the bushing on one end to fit. But they worked great.
mazdapromp3   +1y
I used KYB '69 corvette rears
sncflow   +1y
if your looking for cheap shocks i got mine from napa for about 10 bucks
originalmazdawg   +1y
Then again, the "Toxic Shock" shocks are very inexpensive. You can get them online for right around 40$. The OEM replacements at the local auto parts should be around 20$. I would hardly consider that expensive. If you want cheap, then you might want to try your nearest junkyard. Other wise hit up Oreilly's or Autozone.
gravity5   +1y
Toxic shocks are just OE cheapo shocks with a pretty sticker on them.
originalmazdawg   +1y
I would have to disagree with you on that one, gravity5. I bought toxic's to replace the stockers on the rear of my '86 B2000. There was a very noticeable difference in the construction and ride of the shocks. Beefier and alot more stiffer. But that is from my own personal experience...
gravity5   +1y
Yeah, they might be better than the OE worn out shock that was on their....but the set I had was nowhere near as good as my bilsteins or my belltechs.....I am just biased though.
fantomrush   +1y
Ive heard the Toxic shocks are just rebranded Monroes. If someone has a set let us know the numbers stamped on the side of them and we can cross reference them. I got a set of monroes and they looked just like the toxic shocks.
