Mazda Lowering Static \  loctite 545
loctite 545
views 1823
replies 19
following 10
mazm   +1y
is there another place to get it other than suicidedoors
mazm   +1y
anyone know?
gravity5   +1y
Anywhere that sells loctite...or you can use the permatex stuff....most any automotive supply store sells it....I use permatex, it is cheaper and works very well....
burnoutboy   +1y
we used permatex in the shop.....bad news. The boss actually had a brake caliper bolt fall out of the front end of his chopper. we switched to loctite gel. easier to work with and holds tight. a lil pricey, but worth the extra couple bucks
phatkix   +1y
prolly used the wrong kind as there are soooooooooo many flavors
gravity5   +1y
545 is thread sealant not threadlocker.... and the permatex stuff works great....Of cousre there is Hetlube too...and it works rad.
Permatex high performance thread sealant white with blue writing
gravity5   +1y
mazm   +1y
are you guys gettin the permatex stuff at autozone or where?
mazm   +1y
what about some permatex medium strength threadlocker
devb22   +1y
Same here!
Dev
