ive been looking at pics of different 4 links. Some have the top bars coming from near the top of the diff to the front ( \/ ) and some have them going from closer to the frame coming off the axle ( /\ ). which setup would better keep the axle from moving side to side?? also some i see the lower bars are longer then the top ones which is better for that. im going to have bags on bars if that makes any difference??
devb22
This is what I am running!
Have never had any problems! Forward Triangulated 4-Link
Good luck!
Devon
devb22
That picture was taken a long time ago!
The setup has been updated since then!
Dev
mazda23
are all the setups that i listed basically about the same for strengh and stuff just a little bit different design??
balcar
your roll center for the rear will be different, but for 100 HP mazda trucks, either or is fine.
mazda23
i dont want to just keep starting new threads so ill ask all my questions in this one.
which kit would you suggest??
from suicide doors:
* Viair 450 or 380 Compressor
* 5 Gallon 8-Port Tank
* 8 SMC 1/2" Valves
* 10 Switch Box
* 2 Airlift Dual Needle Gauges
* 1 Airlift Single Needle Gauge
* Pressure Switch
* 30/40 Amp Relay
* 50' of 1/2" DOT Airline for bags
* 50' of 1/4" DOT Airline for gauge
