lift spindles
lift spindles
carolinasled
from aim. $199 will they fit 2wd and are they legit?
2fine89's avatar
2fine89
I have also seen these advertised ! BUT no accompanying pics with them - nothing about spindles on their site either.
carolinasled
might have to give them a ring tommorrow.....
carolinasled
they dont exist, again aim sucks
2fine89's avatar
2fine89
RAT BASTARDS
kill em all
valiant's avatar
valiant
ok if guys modify thier arms to accept toyota drop spindles for a 5 lug swap, why not purchase lift spindles for a 2wd toyota and modify your arms to accept them?
limequat's avatar
limequat
What's involved in the toyota spindle swap? Does it work for 4x4?
valiant's avatar
valiant
I dont know, I just remember seeing a thread on a 5 lug swap where someone plated their UCA and LCA then drilled the holes for toyota balljoints and put the spindle in on the new ball joints.
for a 4x4, I guess you would have to check the angle of the drivershafts amd make sure they arent at an extreme angle.
realisticly, it might even be better to buy a whole late 80's toyota 4x4 lift kit, pick up a toyota front diff and suspension and bolt/weld it onto the trucks. If I didnt want to do some serious off-roading in my 4x4, I would most likely do that. I do not quite understand the point of having IFS offroad when a solid axle does just as good and can take more abuse, easier to lift. I guess since the diff stays in the same spot and only the axles move, I guess that would save on driveline angles and stuff, but then you have a whole new problem with the axles moving. I dont know, maybe I will have to look into this, maybe the mazda diff and axles would work with a toyo lift with little modification, hmmm.
dangit Limequat, you got me wanting to put a 4.3 in my 2wd and now your making me question if I want to look into a IFS lift for my 4x4, you instigator you <img src="{SMILIES_PATH}/icon_biggrin.gif" alt=":D" title="Very Happy" /><!-- s:D -->
-Mike
limequat's avatar
limequat
Lol, causing problems again!
2fine89's avatar
2fine89
HAHA Nice
