Mazda Lowering Static \  spindle wit 14's
spindle wit 14's
views 1913
replies 16
following 9
slamditbig   +1y
playing around today before i took my drop spindles off.i think i can run the 14's with a wheel spacer and little longer studs. it still tucks inside the fenders. has anyone one done this? i think im gonna try it.
slamditbig   +1y
ok since no one would reply..... j/k ok. i put a spacer on and the mazda stock wheels will fit with about 1/4 inch of lug to grab on. so... im getting longer studs(if i can find them) and a 5/8 inch spacer to be on the safe side.
balcar   +1y
Why are you running a spindle? Mazda will lay with stock 14 wheels and tires without them.
baggedb22   +1y
how are u running drop spindles on a 14" wheel the tierod end will rub the inside of the wheel!!!! you can barely get away with a 16" wheel and a couple washers. And like balcar said u can lay out up to a 17" wheel with no spindle and some simple mods...
slamditbig   +1y
i havent driven it on the road yet but i have a 1/2 spacer with the fourteen" wheel and it sets the wheels out far enough to clear the spindles. i just set them like that to move it out of the shed. i will either get bigger rims or switching back to the stock spindles before i take it out.
sierrax   +1y
What kind of ride do you get without using spindles or any other "conventional" parts? I assume that your flipping the BJ, reindexing the torsions, etc.
I just put my spindles in and flipped the ball joints. It gave me 3 inches and I still have good travel, so why not run them? I don't see any downside except for the fact you have to run 16+.
slamditbig   +1y
cause i ave drop spindles. not regular spindles. the steering arm hangs down and causes clearence issues.
balcar   +1y
1. spindles are expensive. (not that expensive, but they will be once you finally get them cause u have to deal with aim)
2. They push the wheel out a little, which gives many people clearence problems. (espeically if its bagged)
3. I've seen a 15" wheel fit, its just depends on the offset. Its just not worth the headache to spend money to have issues to have fitment issue.
I have a set on the shelf for when I find a crew cab, then it will be to clear the 20-22" wheels. Heck, ihave just about everything exept the cab right now to make it, someday i'll smuggle one back from mexico.
slamditbig   +1y
well i got these for 40 dollars so couldnt really turn that down.
slamditbig   +1y
well i got these for 40 dollars so couldnt really turn that down. you know what other wheels would fit?
