Mazda Lowering Static \  Lower Ball Joint-Won't come off!
views 1478
replies 12
following 8
devb22   +1y
Anyone else have any problems with thier Lower BJ not breaking loose after you remove the cotter pin and all hardware?
Hmmm....
Maybe I should stick it in the vise? I just haven't heard of it being on soo tight!
Let me know what you think?
Devon
nytrdr24   +1y
go get some pb's blaster (sorta like wd40 but WAY better @ breaking stuff loose) spray it on & let it soak overnight, then in the morning spray it again & let soak a while, then it should come loose....mine was stuck & i got some & sprayd it that evening when i got home, then in the morning before i went to work, when i came home that evening, one swift blow with a hammer & she popped right out!
devb22   +1y
Thats what I just did!
I love the PB its super duper great!
I guess we will see what it does!
Thanks!
Dev
mark   +1y
I've always had to pull mine out with a puller
It can be difficult though because there isn't much of a shoulder for the puller to grab onto so it tends to slip a lot.
devb22   +1y
Ive contimplated that as well!
I have a 6" Gear Puller that will work!
We will let the PB Fester over night and see what she does in the morn!
Thanks!
Dev
gravity5   +1y
I always buy a new castle nut, then unthread the old one like 1 turn and put a piece of wood on hit and crank on it with a hammer...never had a problem.
devb22   +1y
Yeah I have new hardware, so that will be on my things to try!
Thanks man!
Devon
southernrazed   +1y
yea a big ballpeen hammer is all i have ever used...and belive me i worked on some nasty bj's up here in canada...just hit the metal on the sindle really really hard. while prying down on the control arm.
xcoocookalx   +1y
hehehe.....
devb22   +1y
Ok guys, I just woke up from my much needed slumber!
I will be tearing into it in just a few minutes!
I will let you guys know!
Thanks again!
Devon
