twistedsmily@comcast.net's avatar
2 links
twistedsmily's avatar
twistedsmily
ok yeah there is always two sides for everything but i was wondering if any of yall have seen the 2link kit that godfathers sell they advertise it in minitruckin at least its the only ad i have seen for it
well i was woundering if they would be worth it or do a 2link with some square tubing and save some money
just woundering you know always looking at mini truckin things
devb22's avatar
devb22
If you are going to try and make a 2-Link why not make a 4-Link!
Personally I would stay away form the 2-Link,but that is just me!
Good Luck!
Dev
twistedsmily
I dont know i was thinking about that 2 link kit IT looks good
gravity5's avatar
gravity5
2 links are fine for limited travel suspensions where the pinion will not change drastically, but anything over like 6 inches of travel they are not good...you will not have proper pinion angle thruout the travel of the suspension, and they do not allow for much side to side articulation.
devb22's avatar
devb22
Pinion Angle is KEY!
Dev
maz
I have a 2 link in mine. It was easy and cheap to do. It also has a some lever action for the bags. Problems........limited movement (pulls rear 3 wheels) if cornering fast. Pinion angle. but it rides real nice.
mark
I took advantage of that aspect of a 2link when I had one in mine
I used to go around a turn and air out one of the front tires where the weight is going to be and i'll pull a dogdeg going around a turn @ 20mph . It was fun. I had a bar connecting the 2link bars also, so it was extra stiff.
maz
yeah so do I I found it a problem pulling on the roads and stuff when the rear end need to articulate. Just would spin then grab.
twistedsmily
yeah a buddy of mine use to do the whole dogleg move in the parking lot to show off to every one there
