Mazda Lowering Static \  welders
welders
views 800
replies 7
following 6
pimp b2200   +1y
i just bought me a welder finally,i was wondering if you guy could tell me if this would be good for doung c notches, 4 links and front bag mounts.
thanks
jake
heres the link
nytrdr24   +1y
yep'rs, it ought to do the job very nicely, i have the pro-mig 140 which is almost exactly the same thing. you'll have to take your time on the thicker stuff, but other than that it's an excellent 120v welder!
pimp b2200   +1y
cool, thanks
gravity5   +1y
1/2 inch plate with a 120 v welder...hahahaha NO. You can do a notch with it, but make sure to use gas shielding, and use .035 wire.... Even then that welder is at the limit.
southernrazed   +1y
yea you gotta have the gas on the thick stuff..
trashed   +1y
volts arent as big of a deal as everyone plays them out to be. im in the process of getting taught by a certified professional welder and what you need to look at is the hertz. i weld with a 110 snap on and i burns in better than the majority of 220's ive used.
phatkix   +1y
my 220 smokes any 110 ive ever used.
gravity5   +1y
Yes the frequency matters but so does the output amperage, and that little welder puts out 135 A max.....to properly weld 3/16 steel you need between 160 - 190 amp output....
and to do 1/4 plate between 180 and 210...
Now in the product description the welder says it will do 1/2 inch plate....hahahah not bloody likely...to do 1/2 inch plate...guess how many amps output you need....cmon who wants to guess....try around 300 to 320....
That little welder barely puts out enoguh amps to weld 1/8 properly...
Now keep in mind that I am talking about single pass welds, but even with a double pass....there is no 110 volt welder that can put out enough amps and volts to properly do 1/4 plate...at least not as far as I have seen yet.
