over asked ball joint flip?????
toddluck@hotmail.com's avatar
im sure its over asked but how much drop can i expect from doing a balljoint flip??
and will i retain some travel...im sitting right over the fron tires now...i want it to sit where it does now i just wanna gain a lil ride
2fine89's avatar
2fine89
Approxametly 1" if I remember correctly
crazymikey's avatar
crazymikey
you'll probably tuck your front tires if you do it. It's really easy to do,might take you an hour or so. All you have to do is take out your upper and lower ball joints,notch your lower control arm,and bolt the ball joints back in.
But make sure to trim your bump stops!
laydoutb26's avatar
laydoutb26
i can do the lowers in like... 20 minutes... i'm quick with it... never done the uppers...
thanks for the in fo
