ball joint spacers
ball joint spacers
carolinasled
will these work with our trucks and also if it will or we have to get some made will they work on upper and lowers????
tryn not to give up on a mild lift right yet....
gravity5's avatar
gravity5
I would say that they would lift the truck, wether it's safe, and roadworthy is another dilema all together.
carolinasled
well i found this forum thread on i think 4x4wire were they had about 30 pages talkin about invented these a couple years back for the toyota's well i email the guy who is building these at his online page. said if we could send over a pic of the ball joint and upper a arm he would see if they would work or if he could machine some for us. since no-one makes lift spindles for our trucks.....
gravity5's avatar
gravity5
BIOKUSTUMZ would make a custom set for you..
speedster93b's avatar
speedster93b
Do toyota's run the torsion bar on the upper control arm? that's the only way it makes sense to me how these spacers work... if the torsion bar is on the lower control arm, then basically the ball joint spacer would kind of act as camber adjustment. the lower ball joint is the load bearing balljoint, so that means you'd have to space the lower one from the lower arm....
ask that guy that makes them and let us know!!! i'd be interested in a cheap lift for my ranger!
1hotdawg's avatar
1hotdawg
If you're looking to lift your B, check this dude's page out. He's from Mazdatrucking.com's forums. He had spacers made by Cando Specialties I believe, and can get you a set for $130...see his page below
carolinasled
thanx 1hotdawg, who knows i have a hard time makin up my mind......i'll be honest i dont know what i want to do....only time will tell thanks tho now i have a reference.
crazymikey's avatar
crazymikey
In one of the other threads,I think it was carolinasled,who posted a link to a B that was 'done back in the day'. The guy mentioned he lowered the truck by cranking his t-bars and installing ball joint spacers.
So,I assume they could be like a drop block in the back maybe? Kind of like flipping the ball joints,but using a 'block' to give you the inch of drop instead of turning the bj's upside down?
