whats the secret???
12 following
slamditbig@hotmail.com's avatar
whats the secret???
slamditbig's avatar
slamditbig
i have slam re6's. running 200 psi in a three gallon tank. with 3/8 line but the front will not jump, it comes up within a second but i want it to jump or throw it a little faster. what can i do? also how do i maintain enough pressure to play with them? i got enough to go up and down about two times with them front. is that normal?
gravity5's avatar
gravity5
!/2 inch line, put the valves closer to the bags, and bigger tanks.
bagged2600's avatar
bagged2600
An engine driven compressor,is great for more air,I have 1/2" line and valves,and mine will hop a little at 180psi....
slamditbig's avatar
slamditbig
i have a viair 380 and my ac compressor both working together. i was wondering if 1/2 line would do it or not. if that doesnt work i will move the valves
slamditbig's avatar
slamditbig
i have re'8s on the back and it will allmost jump allready.
bagged2600's avatar
bagged2600
I have a viair380 and the a/c compressor,and a 7 gallon tank,on my truck and I got mad air,and Im a switch junkie.
slammedyota91's avatar
slammedyota91
i had 8 gallons, 2 viair 380's and 1/2 valves and line, and hopped a good 6 or so inches at 200psi, with firestone bags
slamditbig's avatar
slamditbig
so it sounds like i need another tank an 1/2" line.
kaoss's avatar
kaoss
why hasn't any one mentioned nitrogen? You have a constant source of air.
slammed83mazda's avatar
slammed83mazda
I have 2 450s, 12 gallon tank, 8 3/8" valves and 3/8" line I can pull the front wheels around 3" at 150 psi
