distance from wheel to wheel....NEED TO KNOW ASAP
smokesdoggyhouse@hotmail.com's avatar
90b2200's avatar
90b2200
what is the distance from wheel to wheel??
FRONT TO REAR WHEEL
89 b2200
NEED TO KNOW ASAP
got my 4 link tonight and need to know so i can make it square.....
thanx N|ck
speedster93b's avatar
speedster93b
this was on this website.. don't know if it's the same or not...
90b2200's avatar
90b2200
yeah i need to know the distance from center of the front wheel to the center of the rear.
speedster93b
what exactly are you trying to do? did you cut out all your stock suspension and forget to measure and mark centerline? DOH!!!
90b2200's avatar
90b2200
yes i did. but i measured it on one of the other mazda's i own and i got 117 1/2"
so im goin off that.
speedster93b
one of the better ways to set it up is to forget 'the measurement' and put the bed back on, line it up and center the wheels and axle in the wheel well and between the framerails when its layed out... and go from there. sometimes it might be off a little using stock measurements, since it was made to sit 14 or so inches higher off the ground.
this way you'll be sure your truck will look good.
southernrazed
yea that would be the best now.. in the futurre leave the laeafsprings on untill your bars are in place.
speedster93b
be sure to setup your lower bars parallel to the ground at ride height.
90b2200's avatar
90b2200
does anyone know what there wheel base is?? when layed out??? i tryied to do it the way stated above....buyt i still messed up and now my truck is off 1 inch......
need help ASAP......... im workin on it right now....
by the way i have a 89 b2200 ext cab...
Thanx N|ck
90b2200's avatar
90b2200
never mind i got figured out....
Peace N|ck
