air shock question
lofosho86@yahoo.com's avatar
air shock question
lofosho86's avatar
lofosho86
what make,model do you buy air shocks for a 91b2200?local parts store doesn't list em for my truck.any help would be greatly appreciated!!
phatkix's avatar
phatkix
monroe makes max air ones that fit. not sure the part# could find out tommrow tho
nytrdr24's avatar
nytrdr24
which ones are you wanting, front or rear, i have a p/n listing for the monroe max-air shocks i got off their site....
lofosho86's avatar
lofosho86
i need the rears,but the fronts wouldn't hurt either!
fanninator's avatar
fanninator
hey man, dont waste your money o tem unessyou haul alot. they ride like ass!
nytrdr24's avatar
nytrdr24
is it @ stock ride height, or do you have it lowered any?
lofosho86's avatar
lofosho86
the rear frame rails are on the rear end.4inch blocks and monoleafed back out,pulled the torsion bars in the front and flipped the balljoints!
nytrdr24's avatar
nytrdr24
here's a link to the monroe p/n files
according to their listing our rear shocks are 5/8" x 1 5/16" loop mounting or "L1". they list four p/n's for shocks that have "L1" loops on both ends which should be a direct bolt in.
ma727 12.75" compressed / 20.375" inflated / 7.625" travel
ma792 13.00" compressed / 21.250" inflated / 8.250" travel
ma812 12.75" compressed / 20.750" inflated / 8.000" travel
ma820 14.375" compressed / 23.00" inflated / 8.625" travel
with yours being so low, and the length of these shocks, you may have to relocate your shocks to get the optimum ride......
the fronts are a little more complicated though, stock we have a 3/8"-16 stem on top, and 12mm x 1 1/4" loop on the bottom...their designations are "S4" for the stems, and "LS23" for the loops on the bottom.....
they have 14 shock p/n's that have an "S4" top, but none of them have a "LS23" bottom, so some modification will be needed for them to fit....i'll list the p/n's for you, but not the dimensions because there is so many. you can go to summit racing or another online parts supplier & look up the part #'s for the dimensions...
ma700, ma705, ma711, ma726, ma739, ma756, ma763, ma777, ma793, ma805, ma809, ma810, ma811, ma815
out of the 14, the ma756 are the shortest...
xcoocookalx's avatar
xcoocookalx
Thanks! I was needing this also.
lofosho86's avatar
lofosho86
thanx bro!i'll see what they can get me
