issue with a 95 rodeo
dbales12@yahoo.com's avatar
unhallowed1's avatar
unhallowed1
I just bought a 95 rodeo and drove it home. Drove perfectly normal and nothing out of the ordinary. Well when I went to crank it up later in the day (have to use jumper cables because of a dead battery) and it'll crank only if I pump the gas pedal and will not idle on its own. If i'm not holding the gas pedal down it won't stay cranked. Any help guys?
8
89zues
if its carb (been awile since seen under hood of one) clean carb with carb cleaner and change fuel filter. if EFI, change fuel filter and run some fuel injector cleaner. also cheak air filter, if engine starves for air it wont idle. if it set awile gas could be bad. theres a gas aditive called sea foam you can get at a parts store. use this with a bottle of outlaw octane booster and itle fix the problem with the gas. only other thing i can thinlk of would be the idle control valve mabey need adjusted but try this last. hope this helps.
Related Discussions in Engine
fuel cell
last post by tycox +1y
0
