Mazda Lowering Static \  need trad. bodydrop help really bad ASAP
views 712
replies 2
86mazyota   +1y
i have completed the cab 2.5 inch bodydrop to the rockers now i am trouble with the radiator support. We cut ii off at the frame and moved it down 2.5 inches and now the brackets for the bars that bolt to my lower control arms is pushing the truck up in the front. The question is do i need these and if so ho much do you lower the front radiator support when welding it back on the frame. lmk ASAP as this is all thats holding me up.
my email has changed to
devb22   +1y
You can get rid of those bars, BUT you will need to put something in place of them!
Short of getting Tubular A-Arms you could do this mod:
Scroll down to find the picture of it done on a mazda lower arm!
Good luck, hope this helps!
Dev
gravity5   +1y
yep just eliminate the strut rods, and make the lower a arm an a arm instead of a sinde mount it will have 2.
