Mazda Lowering Static \  front not laying out
views 1937
replies 16
following 8
mazm   +1y
my setup is re6s, flipped ball joints, notched lower control arms and cut inner fenders, i have 205-40-17 inch tires on escalade wheels. i pretty sure its my upper ball joints binding and need to be re angled, but wanted everyones input and would like to see pictures of re angled upper arms, also my front crossmember is 1 1/2 inches off the the ground
speedster93b   +1y
with that much work and you're still that high, i'd think about your upper bag mount being too low, or at the wrong angle. my whole front end is stock - no flipped bj's no notched anything except the lower c-arm a little around the pivot point, and my front layed out and drug crossmember on 205/60/15's(24.7" tall). your 205/40/17's are 23.5" - almost an inch smaller.
get a pic of your setup...
gravity5   +1y
Uh you should be able to lay out on an 18 without reangling the control arms....something else is binding, or the bag is not installed right or something.
mazm   +1y
what else could be binding though? im pretty sure i got the bag install right i angled the upper bracket up a little and gusseted it down
mazm   +1y
im gonna notch my lowers out some more and see how it goes, if its not that then i have no idea
carolinasled   +1y
do you have a pic of your front end with tire off???
might be better to ask question with a pic.
mazm   +1y
i dont have a digi cam and im not sure how to post pics, sorry man
carolinasled   +1y
take pix from dig camera or phone
upload to computer, or send to email
visit hit browse
click on picture hit open and then hit host it
copy from web page on to forum reply block
instant pic....
not tryn to be a smart ass just lookin out
hambandit   +1y
an easy way to tell if your bag is bottoming out (upper mount too low) is to take the bag out and see where it sits with the bag removed. if it still binds where it does now, its not the bag mount. you might also check to see if your tie rods are hitting anything. if you do go ahead and pie cut the uppers, plate the back side of it to ensure it wont cause problems down the road.
gravity5   +1y
I hate to say this...but if you can't find the whats holding the front from binding you probably should not be doing the work yourself...Oh and I have never notched a lower control arm to make a mazda lay.......
