Mazda Lowering Static \  colorado xtreme rims...
views 2503
replies 18
following 9
imazda   +1y
i have a chance to pick up some colorado rims, the xtreme versions. Im pretty sure they are 17's unless someone can correct me. Im wondering if anyone knows if they will bolt up, or will i have to bore the center/grind the hub,. or even if the bolt pattern is the same. anyway let me know this guy wants like 500 for the set. if i dont buy them and anyones interested i can pass the offer onto you. let me know thanks in advance
pont   +1y
same bolt pattern you will most likely have to bore it out or grind the tabs.
bagdb2200   +1y
You don't have to bore them out. The Xtremes come with 17's and 18's.
imazda   +1y
much appreciated thanks guys
pont   +1y
so does the bigger trucks but you still have to bore out the center to get them to go over the tabs. Or you have to remove the tabs point is they will fit just don't be surprised if you have to bore them out or grind the tabs
mazdawg(mikey)   +1y
no no no the bolt pattern is wrong! its got the colorado trailblazer bolt pattern and its not the same. its goofy like the dakota pattern. its 6lug but not like ours
fanninator   +1y
no its not mazdawg. it is 6x5.5
bagdb2200   +1y
Do you have a set yourself or seen any? I'm just going off someone else who has them, and he said the bore is large enough they don't need to be bored out.
pont   +1y
Like I said they might need to be and might not but don't be surprised if they need to be. If not good saves him some money and time
twistedsmily   +1y
is that like an inch smaller than the mazdas bolt pattern ??
