Mazda Lowering Static \  setting up rear end
setting up rear end
views 843
replies 4
draggin84   +1y
i have all of my four link bars and my c notch's but i can't afford all the stuff to bag it right now but could i use cut coil springs tacked to the bag brackets to set it up? i don't drive it but i would like to keep it mobile in case it has to be moved.
speedster93b   +1y
you could tack in some scrap metal in instead of coil springs. might be easier.
v8mazda4ever   +1y
get everything installed and then use some scrape round bar cut it to the length you want the truck to sit at and just set them between the axle and the notch the wieght of the truck will hold them in place or if you are going to be moving it alot tack them in
speedster93b   +1y
could use 2x4 or other wooden mechanism as well.
draggin84   +1y
ive been bouncing this idea around in my head for awhile now and i originally thought that i could just weld everything up and then put some cut down coil springs in place of the bags but i dont want to get it all together and then when i finally get bags i find out that i didn't compensate for something and the i have to tear it all back apart and start over.
