Mazda Lowering Static \  Front Spindle Assembly, HELP?
views 698
replies 2
following 2
madmazda   +1y
Can Someone Please tell me how a Front Spindle assembly works?
Upper and lower Control arms
Upper and lower Ball Joints
Spindle (or Drop Spindle)
Dust Shield?
Wheel bearing?
Im lost now...I've never took it apart before...
I need full assembly right till the wheel goes on, In order?
Thanks guys.
pimp b2200   +1y
you have it pretty much in order if you have removed all those components it would go
1.bolt on upper control arm
2.bolt on lower arm
3.apply your ball joints
4.then connect the drop spindal to the ball joints,(torque castle nuts to specs) and apply cotter pins
5.then apply dust sheild
6.grease inner bearing the put in back of rotor
7.apply rear seal
8.apply rotor to spindal
9.then grease outer bearing and apply in rotor
10.put the washer on then the nut and adjust till there is no in or out movement
11.then put the cotter pin in
12.then dust cap
madmazda   +1y
Alright... Im ordering some Arms from Cando Specialties, and Im not sure if i should go with Mazda to Mazda, or Mazda to toyota? I really want a 5lug, and a few people said i could swap out rotors, and calipers i believe, but im not 100% sure upon that, as i dont see how the bearings will fit a yota 5lug rotor on the mazda spindle...does anyone know the answer?
