Mazda Lowering Static \  five lug rear conversion
views 780
replies 4
following 5
mazstang   +1y
was just wondering if a rear end from a 85 yota will bolt right up or not
thanks in advance for info
joshbrennan   +1y
nope, i just got a rearend out of an 87 toyota (same generation) and it looks like i am going to have to get the driveshaft shortened some and get the u-joint assembly (pinion mounting flange, u joint and tube yoke) from the toyota put in the place of the mazda one.
blue crush   +1y
I have a mazda rear end redrilled to 5 bolt.. comes with newer brakes..$250.00
toms87   +1y
I had a 5-lug conversion on mine. i just drilled the hoels a little inward and then grinded down on the thick part of the driveshaft where it meets the rear end so the bolts didnt go in sideways and it worked perfect. ill post picks later
ga,mazduh   +1y
hey toms87 can u get those pics up hell im to that point and would like to do it that way if it is easier...low intentions 4 life
