Mazda Lowering Static \  can you replace a step notch?
views 823
replies 6
following 5
titancustoms   +1y
I bought my old Mazda back yesterday. The guy that had it had a one piece notch put in and the welds on the notch are broke. Is there any easy way the replace the notch with out doing a whole back half?
hex0rz   +1y
...cut it out?
immortal1 (linn)   +1y
What may work would be to weld some metal to the original frame, before and after the notch. Then cut out the notch and install a new one.
titancustoms   +1y
another problem would be the a new notch is the same size as the old one. What is it going to weld to?
v8mazda4ever   +1y
can you put pics of it up so we can see the problem and give you more advice as if we see it we can get a better perspective on it.
^ good idea
speedster93b   +1y
be sure to support the frame in front of and behind the area to be cut out, as to prevent sagging.
