Mazda Lowering Static \  1989 B2200 torsion bar help
views 1956
replies 6
following 5
1.21 jigawatts   +1y
Hey guys.I just bought a cab plus b2200 in really good shape and im planning on doing some custom mods to it.I was wondering how low i can drop the torsion bars before the bolt threads are done?If i go to far will i be able to torque bolt back in someone please help.Thanks i will post new pics of the truck asap.
madmazda   +1y
You should be able to get a good amount of drop, the only down side if you crank them enough that you sit on your bumpstops your ride will be worst then ever...plus your shocks will take a beating, espically the stock ones. but you can make 17"s hug the fender nicely and still have a decent ride quality...thats what i did before, need pictures, Just ask. or PM me.
v8mazda4ever   +1y
You can re-index your torsion bars and cut out the bump stops. but it depends on how far you want your truck to sit off the ground.
watt   +1y
what does re indexing them do? Does that keep the stock spring rate but at a lower ride height (without bumpstop obviously)? and what would be the difference as to just loosening them?
toddluck   +1y
it keeps the brackets from scraping the ground it doest change the spring rate at all
watt   +1y
ok thats what i thought but i wasnt sure
1.21 jigawatts   +1y
Thanks for your help guys ill see whats going to happen.
