Mazda Lowering Static \  Baggin the front end Questions.
views 1105
replies 5
following 6
themdot   +1y
I've got the front taken apart,swaybars, shocks,torsions. Now that im lookin at it when I pick up the lower control arm ,I can only pull it up to a certain point before it hits the bar connected to the core support.
Do I have to move this bar or what.
How do I determine the angle of the bag plates relative to the ride height..
Is the distance between plates simply height of a crushed bag?
Being humid in florida any suggestions on drianing condensation from bags?
v8mazda4ever   +1y
the way to keep out water is to put a water filter on your tank between the compressors and the tank as well put a drain screw in the bottom of the tank and drain it once a month if you are using your ride alot.
dropitforme   +1y
I've been told by a reputible mazda guy that those rods hit on the sway bar mount and that you just trim that mount
blastation   +1y
i too am starting to take apart my front end of my 86 b2000 and was wondering if anyone has done a write up of how they did it or pictures of what has to be done that would help a lot.
mazdawg(mikey)   +1y
search............try looking at the project section, maybe sparky mazda.
drgnmazda   +1y
i cut the entire hump off the frame , and then cut the lower c arms out around where it hits the crossmember piece , that was the only way i found to be able to lay out and i cant lay frame but i can put the crossmember on the ground and i dont have drop spindles
