wiring
mazda23
I tried to search a bit but came up with nothing. I want to know how to wire up my switch box to my valves. I want 4 switches(one for each corner), 2 more( front to back) and 2 more for (side to side. I don't know what wires are for what switch, basically thats all i want to know if someone can help me. And a diagram would be wonderful but not nessecary.
thanks for reading
Post was last edited on Jul 22, 2007 03:02. Edited 1 time.
slammedyota91's avatar
slammedyota91
suicide doors diagram
fbi's diagram
good luck
mazda23
thanks soooooooo much. very helpfull. Exactly what i was looking for.
Also i have 1/2" asco valves and they have 3 prongs for wiring. I was just wondering where + - go??
slammedyota91
dunno which models you have
typically they go opposite of eachother, but your valvs should have come with a diagram stating what was what
mazda23
theres no wiring diagram. Im looking at they're website to see if theres one there. If anyone has these valves could i please ask how they were wired.
The cat. no.- sc8238s405 and they are series 8238
is there anyway to test the valve for 1 sec without hurting it??
V
v8mazda4ever
Okay on the asco valves you have three pronges the 2 that match each other and the one below. take the one on the left and attach wire out to switch box then the other 2 attach to each other and out to a ground or if you have mounted the valves solid to a steel part of the truck or right off the tank, the valve is the ground and you only have 2 attach the 2 pronges together. If you want I will put up picks tomorrow as Cid's truck I am doing is running asco valves.
mazda23
thanks if you have time it would be great if you could post some pics. Everyones soo helpful on this site.
mazda23
Is there a diagram that says what switches do what after theyre wired?? or do i have to wait and find out. It would be nice if you could post the diagram you used and what buttons did what. The most important thing i guess is to say how many switches i have, its a 10 switch box
V
v8mazda4ever
Ya I will put up picks of the valve wired and In a couple days I can put up a pick of the 10 switch box thats in Cid's truck and show you which switch does what. I have to mark them out for Cid anyways.
mazda23
thanks pics are great they say alot.
